 Re: This peace of progr. works for +/-70% Kategorie: Programmierung Basic (von ManfredW, Homepage - 13.06.2007 18:34)
 Als Antwort auf This peace of progr. works for +/-70% von Hans - 12.06.2007 22:03
> Hallo
> if there is no RXD signal, it does not go always to GeenOntvangst
> is there a better solution for this problem
> the program should run if there is no RXD signal
> #Start
> second=0
> PRINT"#OFF#";
> #Ontvangen
> IF SECOND>3 THEN GOTO GeenOntvangst
> IF NOT RXD THEN GOTO Verder
> GET Var1
> IF Var1=50 THEN GOTO OntvangXXX    'Start code
> #Verder
> GOTO Ontvangen
> #OntvangXXX
> GET Var1       'Óntvangen van de 48 BITS in 6 Byte's
> GET Var2
> GET Var3
> GET Var4
> etc   ..  etc.
first steps of a solution
> #Start
> second=0
> PRINT"#OFF#";
Var1 = 255
Var2 = 255
> #Ontvangen
   GET Var1
> #Verder
> GOTO Ontvangen
> #OntvangXXX
 if Var2 = 255 then GET Var2
MfG ManfredW
Re: This peace of progr. works for +/-70% (von Hans - 14.06.2007 19:44)
    Re: This peace of progr. works for +/-70% (von ManfredW - 14.06.2007 23:00)
        Re: This peace of progr. works for +/-70% (von Hans - 16.06.2007 15:45)
            Re: This peace of progr. works for +/-70% (von ManfredW - 16.06.2007 19:56)
                Re: This peace of progr. works for +/-70% (von Hans - 17.06.2007 16:53)
