THANKs H.J.W THE display is a 4x40 with 2 enable signal for IC1 and IC2 when I switch (E=ON/E=OFF)then must the print"#INIT#"; Again (no tekst) see circuit http://home.quicknet.nl/qn/prive/hbroersen/display.BMP But the display reading is now good So we want to start all over again 1 Sender en 1 reciever serial RS485 The program works good only +/- one out of ten is goiing wrong then there is coming in wrong information the number "50" (start code) is coming on Varbyte1 or Varbyte2 or Varbyte5 on wich the other variable are moving up why is this program so unstable or with other words, how do I get this program stable '******Test Sender ******** put 0 led=OFF #Start TOG Led VarByte1=10 VarByte2=20 VarByte3=30 VarByte4=140 VarByte5=200 VarByte6=255 PUT 50 'is the start code PUT VarByte1 PUT VarByte2 PUT VarByte3 PUT VarByte4 PUT VarByte5 PUT VarByte6 pause 50 GOTO Start '******** Test Reciever ********** AanTal=0 PRINT"#ON_LCD#";"#INIT#";"#CLR#";"#OFF#"; 'Initialize the LCD voor gebruik de IIC bus' PUT 0 #INIT E=ON print"#ON_LCD#"; print"#INIT#"; print"#CLR#"; print"#L101#"; print "****** Dit is een test *****"; print"#OFF#"; Pause 50 #OpStart Minute = 0 #Start IF MINUTE>4 THEN GOTO GeenOntvangst IF NOT RXD THEN GOTO Verder GET Var1 IF Var1=50 THEN GOTO Ontvang 'Start code #Verder GOTO Start #Ontvang GET Var1 'Óntvangen van de 48 BITS in 6 Byte's GET Var2 GET Var3 GET Var4 GET Var5 GET Var6 #Display aanTal=AanTal+1 E=ON print"#ON_LCD#"; print"#INIT#"; print"#CLR#"; print"#L101#"; PRINT "Getal1=";Var1; print"#L201#"; PRINT "Getal2=";Var2; print"#L121#"; PRINT "Getal3=";Var3; print"#L221#"; 'Regel 4, POSITON 1 PRINT "Getal4=";Var4; E=OFF pause 2 print"#INIT#"; print"#CLR#"; print"#L101#"; PRINT "Getal5=";Var5; print"#L201#"; PRINT "Getal6=";Var6; print"#L221#"; PRINT Aantal; print"#OFF#"; pause 150 GOTO Opstart #GeenOntvangst E=ON print"#ON_LCD#"; print"#CLR#"; print"#INIT#"; print"#L101#"; print "****** Geen ontvangst ******"; print"#OFF#"; GOTO Opstart |
