Thanks Peter I wil try this version But way is this program better?? Hans > Hi Hans, > try if this little program runs better on yours. > I stored the references in a table. > On hardware side I used 12 x 3K3 in the button-chain and 1 x 560K from +5V to the AD-Port for recognizing if no key is pressed. By using other values for the resistors you may have to change the Values in the table. > Note that there is only the PRINT command for result output in this example. > I took the listing from an old application and it did run well as far as I remember. > > Best regards, Peter > > > > > ' --- Definitions -------------------- > > define Analog AD[8] ' Inputport > define Eingabe byte[1] ' Input > define Vergleich byte[2] ' reference > define Taste byte[3] ' Button > define Alt byte[4] ' Old Value > define N byte[5] ' Counter > > ' --- Program Operationen ------ > > Alt = 0: Taste = 0 > > #Loop > Taste = 0 > Eingabe = Analog > for N = 0 to 11 > looktab Spannungen, N, Vergleich > if abs(Eingabe-Vergleich)<3 then Taste=N+1 > next > > if Taste = Alt then goto Loop > Alt = Taste > if Taste = 0 then goto Loop > print Taste-1 > goto Loop > > table Spannungen > 152 173 90 0 193 > 111 23 214 132 46 > 68 235 > tabend |
